Is it ruined ?
Front end collision that sent the radiator into the pulleys and crunched them in a bit , power steering pulley is wobbling. Alternator and AC got pushed in, I can see where the ac connects to the alternator is cracked slightly. Being pushed in the tensioner is pushed in with it and causes the belts to rub and cut into the plastic timing cover. I’m really worried the crank pulley got pushed in also. It’s not rubbing on the timing cover but it’s close. Does it look like the crank pulley was pushed in ? Car starts and runs smooth still and Pulley doesn’t wobble. Any help is much appreciated! Thanks for reading
Clean the pulley and remove the dirt and rust.
Find a "dial indicator" and turn the engine by hand, it will indicate any thing bent.
Replace all other parts that are bent or cracked.
