High Beam Lights and Horn
  • Thread starter Donald W via CarKB.com
  • Start date
Hello All
Was hoping for some suggestions, I have a 1995 legacy sedan, 2wd. I don't
have any high beam lights also the horn doesn't work. Tried replacing the
fuses and replacing the headlight bulbs but to no avail...
Any ideas??
Thanks
don
Checked the wiring? Get a test lamp, turn the high beams on, and poke the
test lamp into the high beam wire until you get a signal. Trace it right
back to the fuse box & relays.
Which brings us to possibility #2: You've managed to fry two relays at once,
probably due to heat. Check your relays out.
If you have absolutely no idea what the hell I'm talking about, get a friend
who does to check it out.
-mark
