Bumper cover removal?
P
Philip Procter
I need to remove the plastic bumper cover from my US spec STi to add a
cold air intake. Is there a trick to removing those clips?
Philip
Philip
It helps to use two small screwdrivers, gently prying at opposite
sides of the clip. Take your time as they are easy to break, and
remember that they are considered single-use fasteners. It's a very
good idea to have a bunch of spares on hand because you WILL break at
least a few. Note that there are several different types used, the
dealer parts department will have all the info.
Also I'd suggest doing some research before you install a CAI. On the
WRX and STi they are of little benefit and can actually be detrimental
because they affect the airflow through the MAF sensor which is
calibrated for the stock intake setup. Some brands of intake are worse
than others.
2016SubaruImpreza80K
