Brake caliper lock pin torque
W
wayne
I'm replacing both rear disk brake pads in my 1992 legacy wagon.
According to my Haynes manual, the rear brake caliper lock pin is
supposed to be torqued to 144-204 in-lbs. The front caliper lock pin is
25-33 in-lbs. Is this correct? Why such an extreme difference? I tried to
torque the rear pin to the specs but fear that it will snap off from the
heavy torque. I ended up torquing both rear disk brake lock pins to
around 30 in-lbs. This is how much torque it took to remove the pins.
Is this OK?
Wayne
to torque the rear pin to the specs but fear that it will snap off from
the heavy torque. I ended up torquing both rear disk brake lock pins to
around 30 in-lbs. This is how much torque it took to remove the pins. Is
this OK?
Wayne
Sorry,
It's been pointed out to me that my torque wrench might be calibrated
differently from the manual. My torque wrench is ft-lbs, not in-lbs. My
mistake. I guess I'm over tightening it a bit.
Wayne
kraabet
