Audible tyre (UK) wear warning!
  • Thread starter Clive - Selectron
  • Start date
C
Clive - Selectron
I posted here a couple of years ago re: dreadful howling noise
from the rear of the WRX under really heavy braking.
Lots of theories but the cause was identified as uneven
wear on the rears as they were close to replacement but
still legal. They wear out of round and develop flat spots
which makes the noise. New tyres cured the problem.
The tyre tech told me that several vehicles wear tyres this way...
all of them 4WD and including Landrover...something to do with
the suspension set-up.
It's just happened again...I thought a wheel bearing had gone
or the rear diff had a problem as the whine from the back
gradually increased over the last couple of weeks.
Then I remembered...got the tyres checked which were 1mm
this side of legal but put new ones on....noise gone.
I had the tracking checked and it was spot on.
Has any one else experienced this phenomenon?
Clive P Norris
Managing Director
Selectron (UK) Ltd
Musical Equipment Distribution.
www.skullstrings.com
www.espguitars.co.uk
www.emgpickups.co.uk
www.tube-shop.com
www.coreoneproduct.com
www.whirlwindusa.com
www.espshop.co.uk
And which tire would that be? A black one or the one with the
white sidewall?
white sidewall?
If you have something worthwhile to contribute
please do so.
If not kindly piss off.
-C-
please do so.
-C-
If you were to provide useful information (such as the tire model)
we won't have this problem, would we?
The car is stated.
The size is a given.
The make of tyre (UK sp) is irrelevant.
I am asking about rear suspension setup causing
uneven wear and thus noise.
If as common as I'm told other WRX/STi drivers
will have experienced it.
To avoid more snidey remarks....
OEM Bridgestones, Michelin Pilot Sport,
Michelin Primacy...not the tyres, it's the car.
Read the post.
-C-
The car is stated.
The make might be but the model ain't.
Could be. Did you take the rear wheel off to see if
any bits are loose? There are no adjustible suspension
parts in the back, but, obviously, some nuts could have come undone.
Some loctiting or safety wiring goes a long way to prevent that.
While at it you can ditch the 17mm sway bar
and the wussy springs. 20mm sti takeoff is cheap but I advise
you to get a 22 or 24mm one. And it's so much better
with the black us oem sti springs. Pink jdm springs are stiffer
yet. Takes vomit inducing body roll out of driving the car if you know
what I mean.
Prodrive must have a ton of suspension bits for you also.
