all wheel drive
P
peter
I'm sure this topis was discussed plenty of times here but since I'm new
to this could any one bother explaining this one to me one more time?:)
I drive Subaru Forester X 2004 Automatic. Subaru's website says that
"...All-Wheel Drive system (featured on models equipped with 4EAT) can
anticipate wheel slippage and tranfers power to the front or rear with the
best traction even before slippage occurs". What is the split under normal
traction conditions - is it 50/50 like with 5-speed manual transmition
models?
Thank You:)
with the best traction even before slippage occurs". What is the
split under normal traction conditions - is it 50/50 like with
5-speed manual transmition models?
90% towards the front, 10% towards the rear.
Yousuf Khan
According to Subaru of Australia and Subaru of America the default ratio for
the 4EAT in the Forester is 60/40 and for the same year Impresa GT it is
40/60.
I have read that selecting 1st or Rev. in the 4EAT switches it to 50/50.
1 Lucky Texan
models?
Thank You:)
From the technical manuals:
For the 4EAT Phase 2 automatic transmission system using VTD (includes the
H-6 VDC)-
1) "Assuming the friction of the front and rear tires is the same (normal
traction condition), the power is split 54.55% to the rear and 45.45% to the
front"
2) "The TCM adjusts the duty ratio of the MPT clutch to maintain the optimum
transfer of power. A large speed difference in the rear to the front wheels
results in the MPT clutch locking the Read Drive Shaft to the carrier. Power
is then split 50% to the front and 50% to the rear."
John
From reading various places, my understanding is 90 front/10 rear usually,
going down/up to 60/40 if conditions warrant. I don't know about selected
first or reverse gear being 50/50.
HW
H-6 VDC)-
Except that the Forester doesn't have a VTD transmission,
which has a center differential. The Forester only has
a transfer clutch which is only used to send power to the
rear under certain circumstances (which have never been
defined by anyone publicly).
The engine on the Forester is directly linked to the front
wheels, while the rear wheels freewheel under normal conditions.
Carl 1 Lucky Texan wites :
If it did this you wouldn't be able to turn the thing.
50/50 means a locked transfer clutch.
I'm not sure I ubderstand this statement.
It doesn't mean the differentials aren't working.
1 Lucky Texan
Correct.
The 4EAT (Active AWD) is usually listed as 90/10 under steady-state
cruising. When hard accelerating or rear wheel slippage occurs it can go
up to 60/40 (maybe 50/50 in lower gears?). The 'duty solenoid 'c' gets
it's duty cycle shifted by the TCU to engage the MPT clutch less or more
as is required.(so I've read-something like 100hz). The
default(interrupte signal,broken wire) condition is full activation of
the MPT clutch. Installing the FWD fuse supplies 12V constantly. Forcing
full DISengagement of the MPT clutch.
The VTD 4EAT is approx. 55/45
I don't know if this yet different again for the VDC.
1 Lucky Texan
my 5MT is 50/50 all the time and I don't have trouble parking.
Actually, no they don't completely freewheel. There is a non-zero minimum
friction in the front-to-rear clutchpack, so there is always some minimal
amount of power going to the rears. Depending on how tight the clutchpack is
set to, you can set the default AWD split at anything from 90:10 to 40:60
depending on Scoobie model.
Yousuf Khan
Yousuf Khan
So where does the STi fit in? Does it use the same AWD system as all
the other subies? I know it has a DCCD. And 60R/40F is the standard
power distribution when running with it in Automatic mode.
BlueSTi
"Scary-Fast"
In a 5MT, you have a differential between the front and rear wheels. So
during turning and stuff, the front and rear wheels take slightly different
paths around the corners (the rears actually take a shorter distance). So
during turning, you don't actually remain at the default 50/50 torque split,
it adjusts to the appropriate split to let the wheels take the right path
around. In a 4AT, instead of a differential you have a clutchpack. So in a
clutchpack situation, when you're talking about a 50/50 split -- you're
talking about a locked 50/50 split. The Scoobie clutchpack actually pulsates
on and off like an anti-lock brake, to allow the front/rear wheels to follow
their own paths around corners.
Yousuf Khan
Carl said:
Correct.
go up to 60/40 (maybe 50/50 in lower gears?). The 'duty solenoid 'c'
gets it's duty cycle shifted by the TCU to engage the MPT clutch less
or more as is required.(so I've read-something like 100hz). The
Forcing full DISengagement of the MPT clutch.
The VDC 4EAT system actually uses a centre differential like the 5MT uses.
But then it combines the differential with the clutchpack of the standarrd
4EAT. The clutchpack in the VDC takes the place of the fluid-coupled
limited-slip system providing slip limiting through a clutchpack rather than
a fluid-coupler. This clutchpack slip-limiter is electronically controlled
so it should be able to provide more "intelligent" active slip-limiting than
the completely reactive hydro-mechanical fluid-coupler.
The difference between the standard 4EAT and the VDC 4EAT is that in the
standard one, the clutch pack is the distribution mechanism from the front
to rear; but in the VDC the front/rear distribution mechanism is the
differential, with the clutch pack acting as helper.
Yousuf Khan
Yousuf Khan writes :
I realize Subaru would like you to think this, but I don't see how
it's possible. Unless it is locked, the transfer clutch will be
slipping, however slightly, which means that the rear end would be
turning less quickly than the front (everything else being cast
aside for the moment). But, since the front wheels are connected
directly to the engine what happens is that the front wheels
pull the car along and the :chassis: will cause the rear wheels
to turn, not the transfer clutch, since it's output shaft is turning
less quickly than the front (or at least wants to).
So, unless the transfer clutch is locked (which you want it to
be sometimes) nothing at all is transfered to the rear.
NO!!!! there is a gearset behind the transmission but inside the same
housing. The gears set ratio is 60/40 which is the default for the Std 4EAT
transmission and that is why the front to rear default ratio is 60/40. God
this thread is getting old. SOA of USA and SOAu says my 2000 Forester ratio
is 60/40 when no wheel torque difference is detected.
I can see where there may be a little 'drag' in the clutch pack even
under steady state level dry hard surface conditions. Tiny sidewall
deflections and very slight slippage on the front would be reported to
the TCU as a 'difference' in wheel speed (compared - as you say - to the
the rear wheels just being pulled along by the chassis). The even
gretaer deflection and slippage under hard acceleration would xfer even
more 'power' to the rear wheels. I think the system may be that
sensitive. Do searches at www.usmb.net www.nasioc.com and
www.i-club.com on 4EAT clutch pack failures. Justa few miles driving
with an undersized spare or tire can destroy the clutchpack and/or duty
solenoid. Perhaps I misunderstand the exact nature of all the nuances of
the 3-4 types of center differential under all conditions in each model
(the number of similar threads on various forums indicates I'm not
alone) BUT I think they work really well.
1 Lucky Texan
People tend to confuse torque distribution with limited slip lockup. The
STi (as with just about every AWD car) has a fixed torque distribution,
based on the gears in the center diff. This distribution never changes*.
For the STi, it's 64/36 rear/front. The DCCD uses an electromagnetic system
to vary the amount of differential lockup continuously. In Auto mode, it
uses various sensors to decide how much slip-limiting action to apply. In
manual mode, you dial in an infinitely variable setting that fixes the
amount of lockup. The torque distribution remains constant, but the center
diff allows torque to be applied to one end even if the other is slipping.
So it's just an electronically controlled limited slip with lockup
capability - no variable torque transfer like the Porsche 996 and Nissan
Skyline (ATESSA-II system) have.
*In full lock mode, the torque distribution is still "64/36", but since it's
locked, it's effectively proportional to the traction available at each
end - on dry ground, this means basically 50/50.
It is getting old. It's almost as if folks don't want to hear it just
because they can't understand it. Sheesh. Even the quotes directly out of
the tech manuals go unheeded.
John
skidude
