When you say a related part—if I’ve just replaced all my tires, should I get an alignment?When it is out of alignment or a related part has been replaced. Otherwise it is a waste or $. I don't think I've ever done any of mine in hundreds of thousands of miles, unless a related part was installed. Even then, marking where it was when it came apart is normally just fine.
I believe that was re-set when installed at Costco. I keep hearing conflicting info about alignment after tire change, so this is very helpful.Ball joints, tie rod ends, etc. New tires won't/shouldn't affect alignment at all. Balance...yes.
