2024 Forester dash noise
A small but irritating noise from the central area of the dash or overhead console - when hitting expansion joints or small bumps in the road - I've emptied the glove box ; console ; removed the dash cam ; felt and pressed on various trim points ; nothing helps. I'm imagining a wiring bundle in the dash that is sitting 1 or 2 mm away from the plastic cover and moving with every little bump .. Anyone out there with this same problem ? .. before I visit the dealer ..
Hit it real hard! Kidding. There’s some foam gap filler btw windshield and dash. Like in my 2018. Press a little bit on that all the way across and see if that helps. My friends outback did something similar. There ended up to be a service bulletin on it.
Neenee
