03 Baja won't start
03 Baja, ran rough, stalled, restarted, ran rough, shut it off and coded P0130x2 & P0171. Changed MAP, wants to start but won't. Can get codes because battery was disconnected to change out sensor. I have changed sensors from working 2.5 to Baja so far:
Camshaft sensor
TPS
Took working 2.5 MAP and tried it
Checked all vacuum lines, no cracks, breaks for leaks.
Even changed the entire Air Intake system from other 2.5 and nothing.
It's got full spark, fuel pressure. Checked and switched out coil pack.
At a loss here now, normally I can get a Subby going in short time no matter what my wife does to it but now, I'm cooked
Would appreciate any and all input on this cause once her Baja is going, I can start parting out the 03 & 1999 Foresters I have sitting here. Body's are fantastic, 03 needs recall A frame and tie rod end, exhaust and will give you more road time. 99 needs one rear bearing switched out, have compete rear end already can switch out entire hub.
Email me (e-mail address removed)
JessDJ
