subaru reliability
H
Henry Paul
I have to agree with the RPMs. I came from an I-6 Jeep and that thing only
ever saw 2k on the freeway.
It seems like my Subie has to turn that much just to get around, and I
commonly hit 3500 on the freeway.
My 2.2 only has 135hp, but it is enough for me. I run a better air filter
and synthetic oil and that seemed
to give me more get up and go.
For parts I like to mail order from Auburn Subaru in Washington. They ship
UPS and the parts get to me
in Utah in 2 days usually. A guy in the NASIOC forum turned me on to them.
They give a 30% discount
for Internet customers. Ask for Jason at the parts desk. I don't have the
number, but they have a web site.
Hello all,
I am considering buying a used (around '99) Subaru wagon. The Forester,
Impreza, or Legacy. They seem quite popular here (Sacramento, Northern
California). And I do like them.
Is there any pattern of mechnical and electrical failures that I should
pay special attention to when I have the car inspected by a mechanic?
Are parts readily available and not over-priced, and is repair expertise
not in short supply? I am a bit concerned about the unique H4 engine.
Does the 165-hp engine give enough power? I cannot afford the turbo.
Thanks in advance.
-LJ
Not a complete list, nor does it apply to all years or models, but some
recurring problems to check/be aware of are (a search of the archives
may help you pinpoint the car you decide on):
Mechanical:
--Wheel bearings (inexcusably short life on many models)
--CV joint boots (and the joints if a boot fails and isn't attended to
immediately--a little more prevalent than other makes I'm familiar with)
--Headgaskets (search the archives, some models have problems, some
don't) leak on some, and even a single instance of overheating can blow
'em on many.
--Rust is a problem with the bodies of East Coast cars, though the year
you're looking at should be reasonably rust free if anywhere but the
West, absolutely rust free if from out here.
--OTOH, rust is NOT a problem on any engine components cuz the engines
leak oil! IME, seals have a life expectancy of about 60k miles or so
(same as earlier timing belts, so if seals and belts are replaced at the
same time, leakage is minimized.)
--Radiator life is about 100k miles before the factory units start to
clog. This is ONE place I suggest aftermarket, from www.radiator.com.
Any car with a single row rad can benefit from one of their dual row
units if one's catalogued for that car.
Electrical/electronic:
--CELs (check engine lights) seem to attract gremlins (again, a little
Parts are ~reasonably~ available (not the greatest parts distribution
system in the industry) from the dealers as long as you're patient (if I
have to wait more than 3 days for my Toyota parts, I'm miffed. Subaru
seems to take that long to locate where the parts are before they even
start their journey to the dealer. Patience is a virtue, they tell me. I
allow a week minimum for parts if they must be ordered, but YMMV.)
Aftermarket parts are less available than more popular makes, due to
much lower number of cars on the road. Also, many aftermarket parts are
not particularly satisfactory. It's my experience ALL filters (with a
possible exception of oil filters: there's lots of discussion on them in
the archives!), CV joint boots and axles, timing belts, and clutch parts
should all be purchased from the dealer when possible.
Prices? If you buy parts from the dealer, try to negotiate on big ticket
items (don't make a pest of yourself with filters and such.) Auto parts
are sold with price lists having several columns: the dummy off the
street price, the guy off the street who's not a dummy, the Subaru
specialty mechanic, the other mechanic down the street, you get the
picture. IME Subie parts are NOT cheap no matter what column you can
talk the dealer into.
Expertise? Most of the Subie owners I know are at least moderately
talented wrenches and do much of their own work. On the H-4, you can do
a lot and save money. Don't know about the H-6. You should be able to
find a reasonable supply of Subie knowledgeable mechanics in NorCal if
you don't like to spin wrenches yourself. Some parts of the country are
better than others!
If it's got a stick and you know how to drive it, yes. Not a race car,
but acceptable. With an auto, you'd best drive the car and see for
yourself (I personally think hooking an auto to a 4 cyl should be a
crime, but lots of people do it.) Easy way to remember how to drive a 4
cyl Subie with a stick: read the redline on the tach, divide that number
by two. Keep the revs above that result. Downshift if you can't.
Spinning that flat four does nothing but make it happier! Driving a car
all day at close to 4 grand scares some people but it's easy to get used
to!
Good luck,
Thanks for the very helpful replies.
Where are the archives? Or should I just google like "99 Forestor head
gasket"?
Have a great weekend.
-LJ
gasket"?
You can do it that way (be sure to spell it "Forester"), which will open
you up to other forums and sources, or you can google "groups" (with the
real www.google.com, not other search engines) then type in
alt.autos.subaru and search from there to stay within this NG.
There are at least a couple of other Subie forums that are good, too:
NASIOC is Impreza oriented, The Ultimate Subaru Message Board's good for
both current and "soon to be vintage" models (like mine?) There may be
more, but those are the two I've visited in the past.
Again, good luck!
Again, good luck!
What's up with the Ultimate S.M.B. Rick ? I've been tryin to get acccess
to it for several days and cannot? Is the problem on my end ?
Gilles (FRag)
Gilles,
Wonder if they're having server problems again? I know they moved at
least once in an attempt to get things "right." I don't go there that
often, but tried this morning after reading your question. Got there ok
thru :
http://www.ultimatesubaru.net/forum/
I had another link that said it contacted the site but then nothing
happened. Maybe that's what you're getting?
Best of luck,
Example google search: http://tinyurl.com/448pv
I love my Subaru's had a 97 Legacy L Wagon I just sold with about
133,000 miles on it. NO PROBLEMS. Never leaked a drop of anything.
My 2000 GT Sedan had the head gasket issue. Both leaked which left me
with a dry radiator and an overheated engine. It was covered by a recall.
