Stopping 05 OWB Seat Chime
R
R. Gerard
My wife saw this online, re permanently disabling that truly annoying
seat belt chime in the 05 OBW.
Is this guy serious or is he pulling our collective leg? Anyone ever
try this? If not, I'll bite and report back:
The seatbelt chime can be turned off by the user. Just turn the key to the
ACC position and begin buckling and unbuckling the seat belt as soon as the
chimes start. Remember to wait until the seatbelt icon stops blinking before
unbuckling. Repeat twenty buckle/unbuckle repetitions and remove the key.
The chimes should be disabled the next time you start the engine. The
process seems to be finicky so you may need to repeat it several times
before it takes hold.
Bob
sounds like a joke... you know that old "how to keep a retard busy -- see
other side" business card where it's written on both sides.
Bloody hell - if you have to fasten and unfasten the buckle 20 times and
then possibly repeat it, wouldn't it be a whole lot easier to perform a
short act of self preservation and get into the habit of actually
*wearing* the thing before driving off each time. (That way you get at
least 20 bonus trips in your car). Plan B is you could probably locate the
buzzer then remove &/or shoot it! Cheers
Hello:
This ought to be a joke but it's not.
It actually works. I performed this sequence on my 05 Outback about a year
ago to (partially) disable the chime. Afterwards you can sit in your car
while idling, and ubuckle the seat belt -- no chime will annoy you.
However, if you put the car in gear and forget to buckle up, it will come
back on.
I had to perform the sequence a couple of times before it worked.
Griff Jones
You could get into the habit of actually wearing your seatbelts I
suppose. I mean if you repeat this buckle/unbuckle trick 20 times, then
you must have had plenty of practice with using that seatbelt by that point.
Yousuf Khan
Bob
People who do not wear seatbelts are STUPID.
Ron
And it really doesn't matter if
I'm wrong I'm right
Where I belong I'm right
Where I belong.
Lennon & McCartney
My, my, but what a sanctimonious bunch you all are!
Who said anything about not using your seat belts?
The question was how to _disable_ that really annoying chime so that:
when you undo your belt at the tool booth to fish for change; when,
stopped, you unbuckle to reach into the back seat for something, etc.,
etc., you do not have to suffer that monumentally annoying chime.
Get a life guys. Nobody rides in my car without doing up their seat
belt on
I bet you guys just love the beep..beep..beep..beep of trucks backing
up too. Gosh, if they didn't do that, they'd back right up over
inattentive jerks who might just deserve their Darwin-award like fate.
Sheeesh!
bob
belt on
Sheeesh!
bob
Hmmm ... It's called irony. I don't condone shooting cars either.
Just as an aside, I hope it does work, but removal might be quicker than
the procedure! Cheers
Good response, Hippo. Right on the mark. Thanks for chiming (pun
intended) in. Have a good holiday weekend. bob
First off, please hold off on the sanctimonious lectures on seatbelt
use. I was using them before most of the folks on this board were
born...had them installed on my 1937 Ford coupe in 1956.
The OBW chimes seem uniquely annoying and I succeeded once in taming
them with the many click method only to have them come back when I
reconnected the battery after a long absence. I have tried to recapture
the blessed silence using the "20 clicks" method mentioned in this
thread and it simply won't work for me. Any tips from successful click
magicians would be greatly appreciated.
BTW my Audi has a "chime five times and shut up" feature which can be
implemented from the MMI screen. I can't imagine Audi is less scared of
US lawyers than Subi, but mebbe so.
TIA for any ideas. Is it all in the wrist, maybe??
I just tried the "20 click" method on the seat belt to disable the chime and
it worked - at least for now! The first two times I tried it, it didn't
work, but I tried again and the third time was a charm. I have a 06 Tribeca
and the directions given here weren't quite appropriate for it. The alarm
doesn't chime if the key is in assessory mode, so I turned the key all the
way on and it seems to be ok.
Don D.
Thanks, Don, for the confirmation. I am on my fifteenth try and I must
be doing something wrong/different than I did before. Maybe I will give
it a try with the key all the way on even though the bloody chimes
start blasting in ACC mode on my 05 OBW. AARRGGHHH.
FH
I just tried attempt number 16 and no dice. BTW my 05 OBW also rings no
chimes in the ACC position. Key must be at ON.
So I wonder if the OP misstated the technique or if I am simply too
clumsy to make it work.
FH
Hey Bob,
Could you post the source of the online info you cited, pls. I can't
get the 20 click method to work and I vaguely remember another method
(different number of clicks maybe) which more or less completely gagged
the chime.
TIA
FH
I have the info posted on my web site at:
http://members.cox.net/kamartin/seatbelt.html
Also, here it is in a nutshell (and it sounds nutty, too, but it
actually works for the 05 OB as well as the 06 Tribeca).
Good luck! -Karen in AZ-
Cutoff Function for Seat Belt warning chime
(Works for the 2005 Outbacks and Legacys, too)
Warning: I am in no way responsible for anyone's safety...just
posting this as a convenience.
1. Turn the key to "ON" (not running).
2. Fasten and unfasten the driver's seat belt 20 times in 30 seconds,
starting from when you actually turn on the key. (This will set the
passenger seat as well).
3. Turn the ignition on, and you should be set.
4. Setting lasts until the battery is disconnected or the system is
otherwise reset.
5. If you want to do this as a temporary thing (just for one driving
period), fasten/unfasten the belt 3 times in 6 seconds. The chime will
reset the next time the car is started.
Thanks, Karen.
Interesting that in some models the chimes begin when the key is in
the ACC position and in others not until the key is in the ON position.
With my 05 OBW, no chime in the ACC position; only in the ON position.
I'll try again. bob
Maybe I will give
I followed these instructions from Karen's site to the letter:
. Turn the key to ³ON² (not running).
2. Fasten and unfasten the driver¹s seat belt 20 times in 30 seconds,
starting from when you actually turn on the key. (This will set the passenger
seat as well).
4. Setting lasts until the battery is disconnected or the system is otherwise
reset.
I have a 2005 OBW, LL Bean edition. My chime does not begin until my
key reaches the ON position. As soon as it chimed the first time, I
watched my watch as I did the buckle/unbuckle sequence 20 times w/in 30
seconds..
I then started the engine, ran it for a few seconds, shut it off,
removed the key, opened the door, got out, closed the door, opened the
door, got in, turned the key in the ignition and as soon as I hit the ON
position....THE CHIME BEGAN AGAIN!!!
There must be a difference sequence for different models.
Maybe I have to be wearing those goofy LL Bean gumboots to make it
work on the LL Bean edition?? ;->
bob
Bob, I am on attempt number 20 with our 2005 OBW 2.5XT. I have gotten
exactly the same results you report and have also reported that the
blasted chime does not start till key hits ON position. This is doubly
frustrating since I had it silenced before I disconnected the battery
for summer absence. Some clickers suggest waiting till chimes stop to
start clicking; Karen says click at once. Karen says turn ignition on
after 20 clicks; others say remove the key....but I still haven't
rediscovered the magic formula and I assure you it is a much more
pleasant car without the persistent chime.
FH
skidude
