Rumble and knocking from underneath...
F
FFF
My 96 Legacy GT makes odd noises when driving over uneven pavement. There is a
distinct knocking or clunking sound from underneath the chassis. It does not
appear to come from the suspension components. My first suspicion is the drive
shaft bushing. Any opinions?
florian
Easiest things to fix are probably the best to check first.
Look for loose exhaust clamps. Many rattles and thumps are
caused by loose exhaust components.
florian
Don't know if this is the answer but there is tech bulletin from Subaru
about slack in the U shaped brackets holding the front roll bars to the
frame. The bulletin described the noise as stones hitting the floor boards.
The fix consisted of removing the brackets, applying anti-seize compound,
bending a metal tab(from approx 75 degrees to 60 degrees) on the bracket on
the end opposite the bolt hole and re-installing.
That's how it sounds exactly. Can you direct me to the tech bulletin, if
available online?
Thanks
florian
trykflyr
