remove main pulley
P
Paul
I need to remove the main belt pulley(the one connected to the
crankshaft) in order to change my timing belt. What do you recommend
holding the pulley so that I can remove the bolt?
I was looking at:
http://www.sjdiscounttools.com/lis28500.html
Do you think its good?
Oh and Sears just sold out online out of their large chain wrenches.
paul J
Some actually hold the pulley bolt with a breaker and then have a buddy turn
the ignition.......I don't think I'd recommend that.:)
http://forums.nasioc.com/forums/showthread.php?t=835097&highlight=crank+pulley+bolt
I believe the 'approved' solution is to use ST (special tool) 499977100
CRANKSHAFT PULLEY WRENCH, but I wouldn't know how to tell you to go about
ordering it.
However, you ought to be able to remove the belt without removing the crank
pulley. You ought to be able to remove the belt tensioner and a timing belt
guide or two to release tension and then just take the belt off.
http://forums.nasioc.com/forums/showthread.php?t=785262&highlight=crank+pulley+bolt
I was looking at:
paul J
If you have a manual tranny, pretty sure there is a port you can stick a
big screw driver or something in. There is also a VERY SCARY way to
loosen it. Also, be aware that some books have too low number for the
tightening torque when reinstalling. If someone does not respond here
with details, I strongly suggest you do a search or ask over at
www.usmb.net on this subject. Great folks.
I've done it a number of times and it isn't as bad as it sounds. You
don't hold the breaker bar though - you rest it against the ground. But
- you will need a way to hold the crank pulley steady when you put it
back on and torque it down.
The subaru tool or a home-made one like it is the way to go.
Strap wrenches can damage the rubber dampener in the crank pulley if you
use them to hold the pulley in place while torqueing on the bolt -
causing it to weaken and separate prematurely.
CompUser said:
Think (non-existent)"harmonic balancer", that's
not really there, that's there.
It may have the rubber strictly to reduce NVH without actually having
the mass, durometer,etc calculations/engineering designed into for
'harmonic balancing'.
That is most likely what it is for. The FSM states it is not a harmonic
balancer but it is a dampener.
Regardless of it is for, I have had 2 separate and know of many other
owners that have had them fail.
Neenee
