Question with 2000 Impreza (New Shape)
Matthew Gallen
Hi There,
This may be a simple question,
I have a 2000 Impreza *New Shape and are trying to get the rear window
squirter to go. I cannot seem to get it to work, It makes the noise, but no
water comes out. Any ideas?
Is it fed from the main resovior under the bonnet that serves the front
squirters?
If so, any ideas why this wouldn't be working?
Have tried to unblock using a needle, but made no difference.
Help greatly appreciated.
Best Regards,
Matthew.
I have an older ('98) model but I think there's a separate little reservoir
somewhere in back?
Nope, it's fed from the main reservoir at the front. I've found that to get
the back washer to work you need to keep the reservoir topped up. Once the
water level drops below a certain point their doesn't seem to be enough
pressure to get it all the way back to the rear window.
The older shape does have a rear one, but I cannot locate one on the new
shape... :(
I have topped it up fully, so I suspect there is a blockage somewhere, or
faulty relay, guess I will have to get the shop to look at it
trykflyr
