Legacy 1996 Check engine light problem
macharia
Hi Guys
Recently, my Subaru Legacy '96 started showing the check engine light
for about a minute every time i start it
When i start the car,RPM's go up to 2000 and then start fluctuatin
between 1500 and 1000.This is when the check engine light comes on.O
revving instantaneously,the light goes off and the RPM's come down t
500 which is normal when on idle mode
Could there be a bigger problem building up? Please assist
Rgds
Macharia :
Need to know the code, but guessing it maybe the throttle position sensor.
Blair
Hi Guys,
for about a minute every time i start it.
When i start the car,RPM's go up to 2000 and then start fluctuating
between 1500 and 1000.This is when the check engine light comes on.On
revving instantaneously,the light goes off and the RPM's come down to
500 which is normal when on idle mode.
Could there be a bigger problem building up? Please assist.
Rgds,
Macharia :(
My problem was a engine coolant sensor, but I needed to read the codes
to learn that. Connect it to a computer and see what the code is
MarkG
