Knock sensor
T
Tony Hwang
Trying to locate a knock sensor on 2000 Impreza RS.
2.5 liter engine.
Can some one give me a pointer? Never replaced one B4.
TIA,
2.5 liter engine.
TIA,
Tony, just did this about 3 weeks ago on ours. It is located on the
driver's side of the engine, top side, between the branches of the
intake manifold. There is a picture here -
http://s24.photobucket.com/albums/c30/ddibiase/Subaru/
You need an extension for the ratchet - about 1.5 inches, to get above
the engine block but below the throttle cables. Ours was REALLY tight,
had to use some PB-Blaster on it to loosen it, even then took some
good arm strength. Do you have the P0325 code? I was told that you
should only replace this with the OEM Subaru part.
Dan D
'99 Impreza RS2.5 (son's)
Central NJ USA
Dan D
Central NJ USA
Thanks. I ordered Japanese OEM parts and located it. The fault comes and
goes. Time to replace I guess.
Tony
Golfer74
