how to change a fuel filter in an impreza wrx
matt
I just bought a fuel filter and i want to change it in my '02 subaru Impreza
WRX. I unclipped the hoses, but is there any tool or method to remove the
hoses from the filter? Also, do i have to relieve the pressure first?
Yes you should relieve the pressure first. Remove the gas cap, then
disconnect the fuel pump relay (green connector behind the passenger
side kick panel next to the glovebox). With the relay disconnected,
start the engine. It should run briefly and stall. Repeat this a few
times, eventually it should just crank and not start again. After
about 5 seconds of further cranking the pressure should be out of the
system, however it's still possible that there will be some left so
have a rag handy when you break the lines open, and keep your face
away in case some spurts out.
The hoses can be difficult to remove, if they're stuck try pushing
them off with a screwdriver and/or using pliers to turn the hose back
and forth to break it free. Be careful not to damage the hose. Some
penetrating lubricant may help.
Thanks! another successful weekend project.
jwillin
