FB20 Donor engine oil leak question
Swapping a FB20 in a 2013 Impreza. Looking at the donor engine, it looks like I need to address the following leaks: valve cover gaskets, oil pan and probably more. Asking the smart people out there… your opinion, based on the pics, do I need to add a crank front oil seal, upper oil pan and reseal the entire timing cover? Anything else I’m missing?
Tore down the donor engine and am replacing the o-rings between the upper oil pan and the block, resealing the upper to block, resealing the lower to upper, new gaskets for valve covers and spark plug tubes and new o-rings and sealing of timing cover. Selecting the best parts off of both the seized and donor engines to put together one to install. Fingers crossed. My first Subaru rebuild
Neenee
