I am going nuts. I am replacing g the CV joint for a ‘96 Subaru Legacy. I removed the old one. I put the short stub for the transmission on the CV joint. I keep trying to put the end into the transmission and it won’t go in. There is consistently an inch between the axle and the tranny. P I have put a long screwdriver in the hole and also my finger and nothing seems to be in there. I line it up and hit a board against the outside shaft with the hub bolt. Even if I hit it with a three pound hammer an inch is sticking out. No even tried it with the retaining ring off stub shaft it does not go in. How can I get this to go in?
