ATF leak
Matt Levitt
I have a 99 Outback Wagon which I purchased used in September. In January,
my car started leaking transmission fluid. I brought it to a local mechanic
that I usually feel like I'm not getting screwed at. They replaced the front
axle seal, transmission pan gasket and transmission filter. They recommended
I do a dye test to make sure they got all of the leaks, but I'm just out of
college and figured that I would be able to tell if there were any more
leaks myself. The small puddle of transmission fluid on the floor of my
garage was a pretty good indicator that it's still leaking fluid. I jacked
the car up yesterday to see where it was leaking from. It's hard for me to
tell (mostly because I'm car-stupid), but the 6 or so screws that screw into
the bottom of the pan were all wet with fluid. I did notice that a screw was
missing, one that screws into the side of the pan from the back. I'm sure
that can't be helping the condition, but I don't think that's the only
problem. I'm not sure if I should bring the car back to the same mechanic
and hope I don't get screwed again or if I should just take it to a Subaru
dealer. I've already spent a considerable amount of money on this problem
already, and I would hope that the local mechanic would be somehow honest
and not charge me full-price to try to fix the problem again. Or should I
just feed the beast? It's not losing a lot of transmission fluid.
/rant
I don't understand. They replaced the AT pan gasket and you have oil on the
screw heads and one screw missing. I think they must have done that work on
someone else's vehicle and not yours. Find a good honest mechanic this time
who checks the gasket, replaces the missing bolt and retorques all the pan
gasket bolts. Ed Hayes
I would agreee with Ed if it were not such an obvious error on their part.
Any idiot can correctly replce a gasket so insist they redo the repair, I
don't think they will even want to charge you. TG
They better not charge you.
me should
For starters, the 'missing bolt' was me being car-stupid and paranoid. It
sure looks like it's a missing bolt (why would a hole have threads if a bolt
isn't supposed to screw in there?) But, I did take the Subaru back there
today. They retorqued all of the bolts (free of charge) and, so far, it is
no longer leaking. We'll see... I was driving the Outback rather hard before
this problem started, so I wonder if the problem was my fault. I hate to
baby the thing now, but I can't afford to repair any more damage that I may
cause :)
KristiKat
