'99 OBW Window Problem
R
rd
I have a problem with the drivers window in my 99 OBW. Most of the
time when the window is all the way down into the door, the window
seems to get into a cycle where it can't seem to seat and moves up
slightly, then down, then up, then down, well, you get the idea.
Also, when this happens, I need to hold the window switch in the up
position for a few seconds before the windows stops cycling and
responds to the up command from the switch.
If I don't allow the window to go all the way into the door, but
remain slightly up, the problem does not happen.
Any ideas how to fix?
Thanks.
kraabet
