2010 IMPREZA CHECK ENGINE LIGHT
Yesterday did a FULL FEUL up
This morning (montreal)
1st start failed
Then Checkine light came ON, VDC ON and cruise flashing.
2nd start worked and drove with the car.
Any ideas?
I checked engine code without scan tool and got
P----- NO CODE??
STRANGE, will check engine light turn off?
Or did I do something in correct?
UPDATE light came back on...I managed to capture code
P0340...any suggestions how serious this is?
UPDATE THIS MORNING
8AM STARTED CAR, CEL OFF...
intermittent ISSUE...
ANY SUGGESTION/IDEAS?
update this monring
7/45am started car no CEL
went to TIM HRTONS
8am STARTED car, STUTTERED...P0340 code came on CEL ON
I FORGOT TO MENTION..BUT AT THE SAME TIME CEL STARTED
I OBSERVED TOONIE SIZE HOLE IN MY EXHAUST SYSTEM.
CAN THAT BE THE ROOT CAUSE?
I was told to replace camshaft position sensor 1st and if issue still continues then next step...hmmmm not obvious...
If i replace part camshaft position sensor should I get original or other make?
I have picture of snesor covered in oil is that normal?
see photo
coastalguy
