Won't start in the cold
David
97 Outback will not start when it is REALLY cold! Ignition turns over,
but engine won't start. Once the day warms up, the car starts.Mechanic
last week had the car, but temps were in the 30s, so it cranked right
up, wouldn't you know!
Anyone have the same problem? Find a solution? Thanks.
You say ignition turns over?? Do you mean the engine turns over?? If the
engine turns over How fast or just barely? Do you have a quality 5w30 or
10w30 oil in the engine? Have you had a battery load test preformed and are
all the electrical connections good? Give us more information and respond to
this thread with you answers and results. eddie
Had a tune up done recently? Check or replace spark plugs, wires if needed,
add some injector cleaner and alcohol (gas line de-icer). As eddie noted,
5w-30 oil will make a difference as well.
Ed B.
trykflyr
