Trunk doesn't open or close
Few months ago I strarted having problems when I try to open trunk on my Subaru Outback 2019 (Limited edition), but it just beeps three times and doesn't open. I try hold the button on the trunk for 10 seconds, which does some reset, but then I have to manually push or pull it, which is not easy.
First it was happening once in a while, but not it behaves this way more often than it doesn't. Changing battery in the key knob didn't change anything. It is extremely annoying as often after this reset operation I had even to drive with trunk showing as open on the dashboard. Eventually it may start working, but them stops again. I didn't notice any patterns or correlations.
Did anyone have similar problems and if yes, was there any solution?
Bruce01
