al said:
If you are really good you can upshift through all the gears and
downshift through all the gears (after you get going) with NO clutch
at all. I have done it in many cars and trucks.
the clutch cable broke in my 1972 volvo and i drove all the way home
in the city...!!
Actually, you can downshift to engine brake - using the clutch - without
overtaxing it. Just match engine revs before releasing the clutch, so that
the engine is already going the correct speed for your new gear and road
speed. Wait until the clutch is fully released before lifting the throttle
to provide engine braking and spare your brakes. (Though I'm not sure that
sparing the brakes is a good reason to employ engine braking. I prefer to
use a lower gear in traffic because it gives me better control over my speed
with only the throttle. The trade-off, of course, is increased fuel
consumption. But with gasoline cheaper than bottled water here in the
'States...)
What destroys a clutch is excessive and prolonged speed differential between
the two plates. Raising engine RPM with the throttle to what it will be
with the clutch released *then* releasing the clutch doesn't cause any
additional wear. OTOH, shifting into a lower gear then letting the clutch
force the engine up to the appropriate revs for the new gear will definitely
increase clutch wear. As long as the speed differential between the engine
and the tranny is minimal, so will be the wear on the clutch.
Actually, one should *always* rev match when downshifting, if only to make
your driving smoother and thereby reduce neck strain in your passengers
And I always try to double-clutch my downshifts to save the synchros as
well, but that's probably a bit over-the-top in a modern manual-transmission
car. Old habits, you know. I never got very good at using the heel and toe
of my right foot to operate the gas and brake pedals at once, so I don't
bother with the double-clutching if I'm on the brakes while downshifting.
The only time I do the heel-and-toe thing is accelerating from a stop on an
incline when some dork pulls right up on my bumper. Though I understand I
won't have to do that with my new Subie, since they all have that neat "hill
holder" feature.
And the only time I've ever shifted sans clutch is on a motorcycle. I've
never been brave enough to try it in a car. I can match revs pretty well,
but I don't get it perfect every time -- which is what would be required to
shift without the clutch. I suppose if I was in a pinch -- like with a
broken clutch cable -- I might give it a whirl. But I've fortunately never
been in such a pinch.
- Greg Reed
1976 Cadillac Fleetwood 75 9-Pass sedan
(FS:
http://www.dataspire.com/caddy)
1989 Audi 200 Turbo Quattro 5-Speed sedan
2000 Oldsmobile Intrigue
2001 Chevy Astro AWD (wife's)
2005 Subaru Legacy GT Wagon (when available in U.S.)
