Tires are out-of-round
Y
Yousuf Khan
I went on vacation for a couple of months, and left my Outback sitting
inside my garage during that time. Got back and there is a severe vibration
in the steering above 90kph (55mph). Took it to the dealership to have them
rebalance the tires, and they came back and said that it can't be
rebalanced, everytime they add weight to it in the balancing machine it asks
for more weight to be added. They suggested that the tires are "out of
round". Now these are expensive tires (Nokians) and I'd rather not have to
completely replace them. I was wondering if there was an accepted way of
getting tires back into round. I was thinking that maybe I would overinflate
them to say about 45psi or something and leave them that way for a couple of
weeks of normal usage. Would this work?
Yousuf Khan
Uh, don't overinflate. That's a serious safety compromise.
You may be able to have the tire "trued" or shaved to put it back in round?
Take it as a lesson learned and next time you leave your car sitting for
months, put it on blocks or have somebody come by & drive/move it every
couple of days.
Tires are an important part of vehicle safety. I personally would replace
all the tires.
-T
This used to be a problem with tires with nylon tire cord. I was called
flat spotting and related to nylons glass transition temperature. Spots
would iron out after running on the road for a while. Your's too may return
to normal. The higher pressure may also help.
Frank
Why would it be a safety compromise. Don't these cars come out of the
factory floor with heavily overinflated tires while they are being shipped
or transported to their destiny?
couple of days.
all the tires.
Actually, I did arrange to have it driven around from time to time while I
was away, but the person who was supposed to do it (my brother) never did
it.
Yousuf Khan
Why would extended sitting around change the weight distribution of the
tires? Is there some leak sealant inside that flowed down and collected
on the bottom?
It has nothing to do with weight distribution. The shape of the tire has
changed causing an inability to balance and a vibration at speed.
Check this link out for a device which you put under your car tires to
prevent flatspotting.
http://www.tirecradle.com/tcradle.htm
If you leave a car sit long enough, the tires will get flat spots/go out of
round. It just happens. I don't know why. I have had it happen on my
restored VW bug and a honda that I have parked indefinitely.
-T
I had a car sitting with a flat for awhile. Pumped it up. It thumped a little at first then
behaved like a round tire and worked fine. It was an old belted, bias-ply tire, on an
old car, a long time ago, so modern tires may behave differently. But mine bacame
round again pretty quickly.
Good luck.
Re: Tires are out-of-round
Date: 4/20/2004 6:22 PM Eastern Daylight Time
Message-id: <johhc.164769$(e-mail address removed)>
Why would it be a safety compromise (that *was* a question, right?) ? Don't these cars come out of the
Maybe, but doubtful as it would serve no purpose as the US built cars make it
to the dealers in as little as 1-3 days, and the imported Subies can make it to
the US midwest in 10-14 days from their build date in Japan. Neither of our
Indiana-built Legacies were driven with more than 14 miles on the odometer
prior to delivery.
it.
Yousuf Khan
Good advice.. Well, except for your brother! Use my neighbor - he always
moves my old heap to the other side or end of the drive - just to keep the
appearance of someone being in the house!
But if the tire became permanently flatspotted I'd complan to your dealer
(which you've already done) or then to Bridgestone and ask for replacements or
at least a decent discount on the next set.
Terry - '02 Regatta-Red 5spd Legacy GT wagon, 29,000 miles,
Yakima / TandeMover / Rockymount rack.
'03 Silver Legacy SE auto-sedan - 6150 miles.
'85 CH250 - 4060miles!
To reply, get rid of the "nonsense"
on the bottom?
Sounds like they "flat-spotted". The RE-92 OEMs
on my WRX do that if they sit even 24
hours...takes about a mile before it abates.
I'd try the inflating em to max sidewall pressure
and driving for a week or so. If that doesn't do
it, they're probably done for.
Steve
I would set tire pressure to the maximum pressure indicated on the sidewall
and leave it and drive it for a few days and your trouble may go away. If
the tires have nylon in the cords, the nylon will stretch causing your
problem and should go away. If this doesn't work contact the tire
manufacture for advice or in retrospect may do this first. Depending on tire
mileage you may have a warranty issue. Repost here to keep us informed. Ed
Don't know if it will work with your tires, since this is definitely a
YMMV situation, but I've had tires on a car that sits for months at a
time (not on blocks) "round out" after a couple of weeks of normal
inflation and use. You might try this, keeping the speed below the
vibration point as much as possible, before going for new tires. (Those
who were around in the days of nylon cord, bias ply tires may remember
this as being almost a daily problem!) I've heard of people shaving
tires with varying degrees of success, but I think it worked better for
a tire that was made out of round as opposed to being flat-spotted from
sitting.
Good luck!
on the bottom?
Yes, actually there was some leak sealant in that tire. Would that cause
that much of a difference?
Yousuf Khan
sitting.
Well, the vibration point seems to start just around my normal highway
speeds (55mph and above), so keeping it below that speed would darn near
impossible, considering the local traffic patterns.
But I will try the inflate to maximum technique you suggested.
Yousuf Khan
If you mean the leak sealant that you spray into the tire through the valve,
then yes it does make a difference. That stuff can totally mess up your
balancing.... You need to clean out the gunk and re-balance the tires. Might
fix your problem....
Actually, just talked to the service manager at the dealership and told him
about the Gunk, and he said that they were all requiring more and more
weight to be added, even though only one of them had the Gunk in them. He
did note that the one of them was acting more funky than the others, which
would likely be the one with the Gunk in it.
Yousuf Khan
Keep in mind as tires heat up, so does the internal air pressure. I'd
probably keep it 4 or 5 PSI below maximum to stay safe.
-T
Isn't the max pressure stated as cold pressure? That is, if my tires say 33
psi, I can safely inflate them to 33 when cold and not worry about when they
heat up...they're designed to handle the increase.
-John O
Yes. In fact, you will often see specific warnings AGAINST reducing
pressure when the tires are hot.
Oh, HALE yes!
That's probably your entire problem right there.
Steve
Right on John O. The maximum pressure listed on the tire sidewall is the max
recommended cold pressure. Ed Hayes
