Tire size question for '04 XT
Y
Y2KRedMustang
I really don't like the stock Yoko Geo's on '04 XT (low grip, to much flex
in corners and not very grippy when braking). Any suggestions what to
upgrade to? I live in Denver so winter driving is a must. Also what about
going to a larger tire? What are the sizes that the XT can handle.
Thanks
Java Black '04 XT 5spd
I just took delivery of my XT yesterday and have the same observations about
the tires. I do not need REAL winter tires, so I thought I'd pull the
original wheels and tires for winter use and upgrade to some 235- 50 17s
with a bit wider wheel. There seems to be plenty of room for a slightly
wider tire and this size is nearly the same diameter as the originals so the
speedo will not be affected.
you want a narrower snow tire not wider.
more pressure per square inch
For snow you want a higher aspect ratio tire (60 instead of 50) that is
narrower. Eddie
skidude
