rear wiper motor
David Richards
Anyone got a spare rear wiper motor for a 96 impreza sport estate in th uk?
David
Are you sure that it is broken. Mine stopped working, I opened the hatch, remode the panell, remove the motor assembly, cleaned the axel from the dust and rust, greased it and it is working fine. It took a bit more time than the simple replacement, maybe one hour, because I had to clean it but the motor was fine, it was simply greae and dirt.
To test it, turn it and manually help the wiper arm to go back and forth. If after a few cycle you see the arm moving by itself it most certainly needs a cleaning of the wiber arm axel
Charles
2000 Impreza wagon
Similar Threads
Rear window wiper motor burned out -- again 15
rear windshield wiper fuse 2
Rear wiper motor 13
Weak rear wiper 5
rear wiper motor? 6
Rear wiper motor 1
Rear Wiper Arm Removal 1
Rear wiper motor Legacy wanted 2
kraabet
