jamason56
I have a 2002 Outback VDC Sedan, 3.0 H6 with 128,000 miles. I was
changing my oil a few days ago. The engine was a normal operating
temperature. As the oil was draining, I decided to check the automatic
transmission fluid, forgetting that I was draining the oil (!). I
started the engine, shifted through the gears and checked the fluid
level, which was a bit high. I turned engine off, drained a bit of
transmission fluid and started engine and checked fluid level once
again. When checking the transmission fluid, the engine remained at
idle for a couple of minutes each time. There were no unusual noises
while I was checking the transmission fluid. I finally realized that I
had been ran the engine before refilling the oil. I was in shock.I
immediately put the oil drain plug back on, changed the filter, and
refilled with oil. On restarting the engine, I heard the lifters
refilling for about a second, but this time they were much louder than
normal, of course. I then started checking over the whole engine
listening for any odd sounds of disaster, but everything sounded
normal. I took the car out for a short drive very carefully (and
nervously)... everything appeared to be OK. Later that evening, I took
the car out for a longer drive, and again everything seemed OK. No
unusual noises, or performance issues. Water temp normal, etc. I've
since put about 400 miles on the car, oil levels normal, temps normal,
performance same. The only noises from the engine are the lifters
clattering a bit, the same as they were doing before I changed the
oil.
I realize I am stupid for having done this, but what does everyone
think about any damage I might have done to the engine? Any
recommendations about what I should do at this point?
John
oil.
John
