Outback Climate Control System
JDC
Anyone know if it is possible to reprogram the climate control system? I
have 3.0 2004 outback with auto climate control. I wish I had the old manual
system. The auto climate control is poorly programmed. Who would set an air
conditoner to go on in 0-20 degree weather or randomly change from floor
vents to floor and dash vents, to dash vents for no reason.
I agree that the system is terrible, but the a/c is not necessarily on when
the a/c light is on. The light means it _may_ go in if needed. The auto
feature should only control the temperature, not where the air goes. And of
course, defrost would always need the a/c. Basically, it wouldn't be auto so
much as an electronic thermostat. Then, they need to make it be able to
blend air, not give you either heated air or vent air or air conditioned
air.
And of course, defrost would always need the a/c.
I have what might be a bonehead question: why does the the defrost
always need a/c?
to pull the humidity out of the air... that's what makes the windows fog on
the insides.
manual system. The auto climate control is poorly programmed. Who would
set an air conditoner to go on in 0-20 degree weather or randomly change
from floor vents to floor and dash vents, to dash vents for no reason.
The automatic climate control is probably the feature I least like about my
'02 VDC Outback Sedan.... I agree with you that it seems poorly programmed
and doesn't work as expected. Especially I don't like the fact that in the
car, 70 on a hot day is cold and 70 on a cold day is hot.... I think you
know what I mean. 70 should be 70, period. I understand it's all relative,
but something is not consistent. Also, the lowest setting is 65, which is
cold, of course, but the next setting is 66 which is somethings too warm!
There are times where I cannot find an appropriate setting using the
automatic system.
automatic system.
It might not be in the programming. I am selling my 1995 Saab, with auto
climate control. Before that, I had a 1987 Saab, also with auto climate
control. I hate auto climate control! I just bought a 2000 Legacy L
wagon, and I love the manual controls. With automatic, I spent more time
adjusting it than with manual.
I think one chief reason is that we don't actually crave a given
temperature. We crave a certain amount of heat being passed over our
bodies. Temperature is not the same thing as heat. And our craving
depends on outside temperature, among other things. That's why I think
auto climate control is a flawed concept.
