Oil filters--a Fram story
R
Rick Courtright
As we all know, Fram oil filters have taken a beating here and in
several other venues the last couple of years. Whether they deserve it
or not, I'm not sure. I DO know that my Subie likes OEM filters better
than anything else, and I get lower oil pressure and more valve noise
with Frams, either the bottom of the line orange one or the next one
(whitish-gray) in the line. So I just don't use them any more.
Yesterday it was time to change oil in the g/f's Honda. I stopped at the
Honda store to get a factory filter since the car's still under
warranty, combined with my Subie experience of OEM vs aftermarket, etc.,
and the fellow gets this little bitty filter out. He tells me they've
changed them and the new one's about half the size of the old one, but
Honda says they actually filter better. Ok.
I go home, take a look and the filter appears to be very well made:
O-ring seal, nicely made metal cap at the bottom, fairly heavy like
there's a lot of material inside and so forth. Imagine my surprise when
I turned it in my hand and read "Made by Fram" on the side! Are they
cleaning up their act? I wouldn't think Honda would stand for a poorly
constructed or performing filter with their name on it. What do you
think?
Rick said:
think?
I think it's apples and oranges. When Fram builds filters for an
OEM customer, they build them to their specifications. Honda
most likely gave them and all the other filter builders a
stack of drawings and the company that could build it cheapest
and still pass Honda's quality control got the deal.
Now Fram may or may not use that filter design for their orange-
box filter. I hope they do. But my point is that all we've
learned is that Fram got a Honda contract for filters, not that
they've improved their product line across the board.
As for me, $5 for a white Subaru filter with crush washer is
a fine deal.
The matter is the specification not the brand.
Any one can make good or bad product depends on the specification.
Tony
Just because it is made by Fram, doesn't mean it is a Fram filter. I
would guess it is made to Honda specifications.
Jack
Date: 10/15/2003 3:02 AM Eastern
think?
Reminds me that I've got to look into a K&N! I frammed my car @6wks ago after
an oil change because, IIRC, it was only $12 but my MPG has decreased, now at
@23 as opposed to the 25-26 I had been getting. So I think I'll spring for a
K&N, burn a couple tanks and then get an oil change, and see wth happens.
Terry - '03 Silver Legacy SE sedan - 36 miles!
'02 Regatta-Red GT wagon 5spd - 23k miles
Yakima / TandeMover / Rockymount rack
To reply, get rid of the "nonsense"
91` Legacy L+ with 103000 miles, always used Fram filters and Mobil 1 since
first oil change, never any problems.
Used Fram filters on my '82 GL for years. Engine was running fine at
~316000 mi - never replaced any internal engine parts. Had to get rid of
the car on account of severe rust. My current car which is another '82 GL
has ~238000 mi on it and I'm using Fram filters.
Ed Fortmiller | (e-mail address removed) | Hudson MA
* To avoid getting a lot of SPAM junk mail, I have altered my REPLY-TO
* address. PLEASE remove the leading "RUBBISH" from my REPLY address.
* Any Email sent to the address without removing "RUBBISH" will
* automatically be discarded without me even seeing it.
I used to use Fram (from the mid 70's) until I read a lot of bad
opinions, including one supposedly from a Fram engineer....sorry, the
link doesn't work anymore, but the rest of the article is here:
http://www.frankhunt.com/FRANK/corvette/articles/oilfilterstudy/oilfilterstudy.html
I'm not sure about the older Subarus, but in the 2002 Impreza, the
filter is mounted upside down, which means that there is no
possibility of the filter draining back into the crankcase which will
work in your favor if you get a cheap filter. A few winters ago in
Minnesota, I didn't drive my Nissan altima for a few weeks (had a
winter vehicle) and when I started it up there was a very loud timing
chain rattle until the filter was full. That was a fram filter
mounted in such a way as to be able to drain on engine shutdown. I
switched to an AC filter and never had the noise again
I had my old hot rod at a mechanics house for a tranny swap. When I picked the car up he told me he threw away my Fram oil filter and installed a real filter.
When a good fella does something like that and only charged the exact cost of a filter, I believe all the other bad reports now.
You'll also find it here: http://minimopar.net/oilfilterstudy.html
In all fairness to Fram, people always reference that study without
apparently reading the whole thing. While the base model Fram filter
may be crap, the study actually has very good things to say about the
Fram model one step up from the base model: The Tough Guard™. I just
have problems with people painting the whole Fram line with the same
broad brush and referencing that study to back up a statement that it
doesnt support.
BTW - I use Purolator Pure One™, so I really don't care except that I
think people ought to be fair about it.
work in your favor if you get a cheap filter...
Actually gravity will pull oil down to empty out the galleys, without n
antidrainback valve even if the filter is vertical. Granted, that's not
nearly as bad as 1/3 or 1/2 of the filter volume draining back down with
a tilted filter, but there is still some run-dry time while the galleys
fill back up.
Also, some people may not be aware of this fact, but with only one
exception (one part number in one brand) that I know of, even the cheap
filters have an antidrainback valve. They may be made of inferior
materials (silicone is the best), and so they may leak down over time,
but they do have the valve.
Bill Putney
(to reply by e-mail, replace the last letter of the alphabet in my
address with "x")
People complain most on anything is the ones who are always pennie
pinching crowd. I guess they don't know what "you get what you pay for"
means. Those who don't even vote complain most I often notice.
Maybe same kinds.
Tony
Hi, Bill
What you're talking about is one of the reasons I originally said I
don't know whether or not they (Fram) deserve the bashing. In fairness
to Fram, my Subie is the ONLY car I've had that's as darn picky about
oil filters as it is! (And yes, I've tried the Fram Tough Guard in the
Subie--no joy. Just as much valve noise--even after using MMO for some
time--and loss of pressure as with the orange ones.) So it generally
gets OEM unless I'm feeling "experimental."
OTOH, I've gotten nearly 200k miles out of one engine, 135k out of
another (it got stolen--but I know 200k or better would have been quite
likely there), using just everyday orange Frams and Castrol GTX. No
exotic filter, no exotic oil, just a 3,000 mile change routine (and we
don't need to get off on THAT tangent here!) But then I've also gotten
over 100k out of a couple of engines that didn't even HAVE an oil
filter, again with dino oil and the same change interval (sold 'em, both
running quite well), so maybe filters are overrated WRT their
contributions to engine longevity.
Any idea why Subies seem so picky about oil filters? A buddy (who ran
Corvairs years ago) claims "hydraulic lifters + flat engine = valve
noise." Period. Could he be right?
Rick said:
...Any idea why Subies seem so picky about oil filters? A buddy (who ran
Certainly seems that way since Subes historically have touchy lifters.
I guess what he's getting at is that with a "normal" engine, the lifters
tend to be vertical or close to it, so gravity helps in getting the oil
into the lifter port, whereas, wiht the lifters laying over, the
diesingers have to fight an uphill battle.
Bill Putney
address with "x")
My local garage put a Fram filter on my 2.5 legacy and it leaked terribly
from the rubber seal. I had to replace it with a genuine Subaru item.
David
Did you compare them when you replace the filter. I think the Fram
filter was wrong one(look alike at glance) or they did not tighten
it enough causing a leak. Fram is not that bad.
Tony
Seems there was a discussion maybe a year ago (??) about some of the 2.5
engines not using the same filter number as others? I'm guessing Tony's
right that the wrong filter was installed (assuming somebody checked for
tightness before pulling the leaky filter?) Leaky filters from "factory
defects" seem to be pretty rare today. "Installer defects" are a
different story!
different story!
Also a possibility that it got double-gasketted (old gasket stuck to
filter bracket), though some of the other possible explanations sound
more plausible. Just thought I'd mention it.
Bill Putney
address with "x")
True. Although it really didn't occur to me cuz of the way I was trained
as a kid working in a gas station (back when they were "service"
stations! And dinosaurs still walked the earth? :D)
Anyway, my boss was a PITA about inspecting the filters we took off for
gaskets, and wiping down the face of the filter mount just to make sure
there wasn't a spare stuck on there. He'd have KILLED us if there was a
failure due to a double gasket--I think "not guilty by reason of
installer defect" would have been his defense!
Well I tried tightening it before trailing to the dealership to buy a new
one and it helped a little, but not really much.
When I took it off, it looked fine (apart from being covered in oil). I
didn't notice any gasket problems.
The Subaru item looked _identical_, although I didn't measure it. I thought
at the time 'This is going to make no difference at all' - but I was wrong -
the leaking stopped dead.
David
jwillin
