Kelly Springfield belt - 1988 GL Wagon 4WD
A
Aron
Hello all,
I have and '88 GL wagon. I recently got cheap belts at AutoZone to
replace the front accesory belts. I got the correct belts for the
options, which are power steerign and A/C. The front-most belt fit
OK, but the one behind it would not fit over the tensioner (fully
retracted) and I did not want to force it excessively. I probably
spent over an hour trying every which way to get it on without
damaging it. So I brought it back to AZ. The belt was verified to be
the right number. I compared it to a couple others of the same brand
and they were the same. AZ also carried a $12.99 Good Year(compared
to something like $3.99 for the KS). This belt was maybe 3/16"
longer, just the extra I needed. Rather than get sucked into getting
upcharged, I took my money elsewhere and got a belt at a local
CarQuest. This belt was on in seconds, it was the perfect size. Has
anyone else had this problem with the Kelly Springfield belts being a
hair too small?
hair too small?
I haven't used K-S belts, but this is not an unheard of problem in my
automotive adventures over the years with a variety of cars and brands
of belts. What I've done in the past is have the guys at the parts store
look in their book for the next size up (or sometimes down) in the same
brand belt and try it. Then if it works, I write the number in MY book,
and ask for it next time. Usually seems to work for me, and since you
were only 3/16" or so from a fit, there should be enough adjustment to
handle the next size. Another option is to take your used belts to the
shop--they all used to have belt measuring devices. Don't know if they
still do since so many are just chain stores now.
amerkflack
