Hi Mike, All!
If I want to disable the ABS
This on my '02 WRX; pull the ABS fuse located in the fusebox beneath
the L. side of the dash. ABS warning light illuminates to remind you.
Most who desire this ability will wish to install a switch to
dis/enable the ABS as required.
While the ABS found in my pop's newer Caddy is quite good (at least on
ice; I was _very_ impressed), the ABS as found on my WRX, and also on
my wifes '02 Forester isn't. While it works as advertised on dry
pavement, it performs _very_ poorly on extremely low traction surfaces
(glare ice; KLUNK, slide, KLUNK-KLUNK, slide some more . . . spooky),
and is less than optimum for aggressive driving on dirt or gravel
(i.e. rallycross, or just havin' fun in the woods) where it's
activation dramatically reduces slowing/stopping distances (It feels
like air in the brake lines).
I don't wish to argue the point; if you're happy with the way yours
works, don't mess with it. If you drive on bumpy dirt roads
(especially if you drive aggressively), or on ice (especially in hilly
terrain), try it both ways and see which works better for you; only
takes a second to pull/replace the fuse.
