Compression for 02 WRX?
Ned Pike said:
The shop manual says 8.0:1.
CR = 8.0 is correct... 8.5 is too high for a turbo motor that runs 14 pounds
boost.
Or, did you mean what is the normal PSI for a compression test? Common
question after someone cooks an engine by using a manual boost controller.
Spud.
Mike G. said:
Does anyone know the factory stock compression numbers on the 02 WRX?
Mike
Are you looking for the compression _ratio_, or the actual pressure?
jwillin
