Chinese driveshafts
Thank you in advance for reading. 2009 Forester X 5spd. Replacing the propeller shaft and have bought 2 Chinese aftermarket, different vendors and appear different manufacturers. Problem is the front yoke only goes in about a 1/4 of the way then just stops. No matter the clock position. With the naked eye they appear the same. The old one slides right in. Before I spend 600$ on a more expensive version I am wondering if anyone else has run into this or if my vehicle is possessed. It's not an application issue. Seems a quality/manufacture issue. Thank you again.
Update. I took the yoke off the replacement shaft that the vendor didn't want back and tried it on another transmission. It didn't fit correctly. So beware of cheap replacement propeller shafts.
If you think THAT is "bad" , .... I recently bought some electrical Switches from a Similar Oriental Supplier ... and discovered that they had NO IDEA what a "NO" (Normally Open) and a "NC" (Normally Closed) Switch Contact IS ... !!!
And their PROBLEM was Universal across their ENTIRE ELECTRICAL SWITCH PRODUCT LINE !!!
OR , ... maybe their A-I Phone App was just having a Migraine the Day that they Spec'd their Products !
Neenee
