ABS Light
John O
I had to put the spare tire on my 99 OB this morning...after borrowing a
wrench because there isn't on in the car...and after about 50 miles the ABS
light came on. The light was off after reaching my meeting and letting it
sit for a couple hours. --got the tire fixed before coming home...
Was that light possibly on because the spare is a different size?
John O
Most likely.
Um, IF you have the auto tranny - did you use the FWD fuse under the hood?
1 Lucky Texan
Use of this fuse locks vehicle in front wheel drive disabling all wheel
drive function. Protects the all wheel drive from unnecessary wear until
you replace your regularly sized tire. Sounds as if you need to read your
owner manual.
John O said:
What do you mean by, "use the fuse"?
(yes, it's auto)
-John O
Carl 1 Lucky Texan said:
Most likely.
1 Lucky Texan
the
owner manual.
I just did that, and after reading the entire section on using the jack,
tightening the lugnuts, and not going over 50 mph with the spare...on the
next (last) page is the deal with the fuse. By the time I got to this part,
I was pretty convinced this fuse thing wasn't there. Being someone who
writes (and reads) user manuals for a living, if this fuse is Very Important
that fact is not conveyed in the manual. Maybe a sticker on the tire itself
would be appropriate.
BTW, I did read the manual when I got the car. If I were writing the manual,
there would be a section right up front called "What's Unique about an AWD
Subaru" and stuff like the 2WD link and towing would go there.
Anyway, thatnks for letting me know guys. If I disable AWD do I get better
gas mileage??
-John O
KristiKat
