P
peterf
Does anyone have a procedure for replacing the expansion valve on a 92
Loyale (EA82)? I'm nearly certain that this is the cause of the
over-pressure poor cooling problem. The system has been evacuated and
recharged with the correct amount of R-12 but shows very high pressure and
at idle, cycles the compressor because if the over-pressure condition. At
higher rpm or while moving, the ac functions but not very well. I think this
is a partially plugged expansion valve but not certain. It looks difficult
to remove and a procedure would really help. Thanks in advance.
