What and where is the "swirl pot"?
The Swirl Pot is a mystery to me as well. It might be a British term or
aircraft thing. I have e-mailed Al Wick for more details..
Here is a link to the Al's webpage:
http://www.maddyhome.com/canardpages/pages/alwick/engine.html
Where he states:
It's essential that the 2.5 liter coolant crossover tube atop the
engine be drilled and tapped. This allows user to add a small tube from
there to the coolant reservoir.
And from a recent post in another forum it looks like doesn't recommend
using the overflow. Is there a difference between the overflow and the
coolant reservoir?
1st.Only air in the block and higher power settings will cause the head
warpage. Every single occurrence (per my mechanic source) is traced
back to the owner changing the coolant and not knowing how to purge the
air.
2nd. It's a design oversight by Subaru. Due to sloping hood and vehicle
height, the air in block can't move to radiator. It stays in block. The
radiator isn't mounted high enough relative to engine. There are a
number of other manufacturers that have this problem, without the head
warping. They just overheat until customer takes it to dealer and he
burps it. Some place a bleed valve at the engine block. Just open valve
until water starts coming out, close it.
True, you would not want to run the tube to overflow. Your cooling
system would then no longer be under 7 psi it normally is during
operation. You just want the air in block to move higher and out of the
coolant flow. My bleed line is the most robust approach, but you could
also just make sure you loosen hose clamp until fluid comes out. That's
what dealer does.
