02 outback head gaskets ?
  • Thread starter Michael R Kirschner
  • Start date
Michael R Kirschner
I think I have been hit with the head gasket demon. I was doing my o/f
change yesterday and I always check the underside of the engine while
I'm down there . Well I noticed some weeping liquid coming from the
driverside head gasket .Around the # 4 cylinder .It is mostly on the
back side and bottom of the block by the firewall. It is a very little
amount not enough to run down the block and drip on the ground . I
can't tell what it is because it is black in color and feels gritty
probable from picking up road dirt and sand from the beaches here . It
almost looks like when you drop some oil while filling up you car and
you don't clean it up ,it attracts the dirt and grime from the road .
I then checked all the other areas and found no other weeping. I don't
have to add any oil between changes . I am not losing any coolant and
I don't have any overheating problems .I have checked the coolant tank
after driving it appears normal . Is this normal for them to weep
alittle or is it the start of head gasket problems . I have a 02
outback 2.5l 4eat with 37k miles on it .
Mike k
Generally, when the head gasket goes, you smell the antifreeze burning. Are
you sure that you are not talking about a front main seal?
..I was able to stop by my dealer today on my way home from work to
have them look at my heads (lol).Well the mechanic and I are becoming
quite friendly these past couple of months . I was able to finally
have them change my timing belt tensioner last month .
Any way back to my heads . The mechanic put the car on the lift and I
showed him were i saw the leak . ON my car you can see better from the
top of the engine .Mine were leaking from the back and bottom of the
block around the # 4 cylinder. When I showed him it said ohh well
whats another one when I do about 2 a week .He said that I caught mine
early because the gasket didn't fail around the coolant jacket . Mine
was only leaking oil. He is going to call SOA and see if he can
autherize to have both of my heads done , since he has to pull the
engine anyway.He said that there seems to be a problem with the late
01 model builds and the early 02 model builds . Mine 02 outback was
built in 6/01.I'm dropping the car off next Monday and he said it will
only take 1 day which seems kinda short to me .
How long did it take to have your head gaskets done . For the people
on here that have had this problem .
Thanks
Mike k
Where do you find the built date? Thanks Jeff
Thanks
Mike k
"Marc Soloway" <(e-mail address removed)> wrote in message
I think it's on the driver door jamb. But I don't remember exactly. I have an
early '02 OBW. I think it was built in 8/01. It has 33K miles on it. And
it's a 6 cyl. Should I watch out for head gasket problems? What symptoms
should I look for?
should I look for?
Any of the following can be symtomatic of head gasket failure
(probably not an exhaustive list):
1.) White, steamy exhaust, even after warm-up (coolant entering
combustion chamber)
2.) Coolant mixing with oil, making a milky oil-water emulsion of the
oil (check your oil, and check the underside of the oil filler cap)
3.) Oil mixing with coolant (have a look at your coolant expansion
tank)
4.) External leaks (the coolant will boil off, leaving a chalky
residue, or drip on something hot...you'll smell it)
Having said that, I haven't heard of any H6 head gasket failures yet.
If you're really curious, give an indy Subaru mechanic a call and ask
if she's seen any (I don't think a dealer's service department will be
honest about this).
One last thing that cannot be stressed enough: _never_ allow a Subaru
engine to overheat. If you see the needle start to climb toward the
upper limit, pull off and stop the engine at once. Subaru engines
(and all-aluminum engines in general) don't tolerate overheating.
2450paul
