wiper motor 1987
B
bgd
Ok, I put a 1993 wiper motor lubed up and ready to launch a chipmunk a
hundred yards as thay shake the car and work very fast.
I go to shut it off and they do not park, they only go near to the bottom of
windshield. I have adjusted, taken things apart twice..
In frustration I took the 1987 original apart and the 1993 to compare the
two...
exactly identical. every move, every part, every wire and even color coding
and alignments...
Anybody know what is going on?
I resorted to putting the 1987 back in just to have the park function, but
slower engine (sped up by silicone sprayed into the motor drain while it was
running.. helped alot, I heard it speed up and stay there). is by freak
circumstance the engine core and brushes exactly in the wrong spot on the 93
to park (that would be a game of less than 2 millimeters- and seemingly an
overthought.)
Anybody have a guess?
bizarre....
two...
and alignments...
Old subes suck.
Not that we needed to know about your chipmunk launching interests.
- Karma
I hate it when those chipmunks shake my car!
Isquat reported moved his windshield up an inch
to solve that problem.
two...
and alignments...
You miswired it?
overthought.)
Pull the wiper ARMS off their mounts. Mount the
motor and connect all linkages, etc. Run it for
a few seconds without the wiper arms mounted.
Slide wiper arms onto their mount points, such
that they will be properly "parked".
Similar Threads
skidude
