Subaru Overheating Problem
H
Howard M. Stark
Sorry to repost but thought that I should mention in the title that the
car is a Subaru.
I have a 1999 Subaru Outback with ~81000 miles. On a recent trip the
engine temperature started to fluctuate between overheat (top of the
gage) and normal every few minutes. I found the oil level down 2 quarts
which I added and the coolant overflow tank almost empty; I added water.
I then drove car about 20 miles before getting it towed to a Subaru
dealer. They found oil in the coolant and feel that either the head
gasket is gone or in addition the block needs replacement.
They might be right, but I have some questions:
1. If there is leakage between the cooling system and the oil why is
there no water in the oil. I don't know the relative pressures.
2. Why the oscillation in temp. This it seems to me might be caused by a
bad thermostat.
I need a second opinion.
Thanks for help in advance.
Sounds like blown head gasket to me. Hope that's all, no warped
head or cracked block.
Good luck,
Tony
Howard M. Stark said:
Combustion pressure make things go wherever it wants to.
bad thermostat.
Again, combustion gas is VERY hot and can quickly raise the temp. A blown
head gasket can be somewhat intermittent but must be fixed or much more
serious damage will result. TG
Isn't there a chemical you can put in the radiator and detect exhaust
gas?
Tony
bad thermostat.
There are actually some little test strips of paper but I can't seem to find
them on the net right now.
I think a "sniffer" for the tailpipe used in emission testing will work if
held near but not submerged in the filler neck.
You can also use a cooling system pressure tester at the filler neck and
instead of pressurizing the system to look for leaks just start the engine
and see if the gauge rises...it shouldn't. TG
Tony Hwang said:
gas?
Tony
You can also pinch off the overflow hose and then rubber band a plastic bag
over the filler neck and see if it expands when the engine is running....I
have found balloons that would fit. TG
I think someone reported on this ng a year or two ago that they
successfully used carbon monoxide detectors (can't rememer if it was
strips or the electronic gadgets) like you'd buy in Walmart, Lowes, etc.
for home use to detect exhaust gas. Do a goolge search on this ng if
interested on tbhe details.
Bill Putney
(to reply by e-mail, replace the last letter of the alphabet in my
address with "x")
I had similar trouble with my '97 OBW back in June. I made the mistake of
going to a Subaru dealership that everyone recommended to me. The
dealership (Carr Subaru in Beaverton, OR) was supposed to have had the
"best" service dept. in the business in one the biggest Subaru regions US
(the Pacific NW). Well, they charged me top dollar ($1600) and did very
poor work.... they forgot to tighten various essential clamps when they
reassembled the engine. So, I had to go through 2 major breakdowns stranded
far away from home AFTER having to spend all that time & money for repairs.
THEN spending much time and effort to get the car BACK to the dealership so
they could fix what should have been fixed properly the first time. They
never even said "sorry about that".
My advice? Take the time to make sure you know and understand fully what the
problem is with your vehicle.... then choose the shop very, very carefully.
Try to meet the person who is actually going to do the work and make sure
you feel comfortable with that person tearing apart your engine and then
reassembling it. If he shows any signs of drug & alcohol use, refuse to
have him do the work. You cannot be too careful about this, especially when
it comes to this sorta stuff. Sounds like you may have some reservations
about this particular Subaru dealership. You may want to get the car
diagnosed at an independent shop, especially if it's a possible blown head
gasket. Hope this helps.
-- Pete
-- Pete
car is a Subaru.
bad thermostat.
Thanks for the advice.
Howie
Oil pressure is higher than coolant pressure therfore oil only in coolant.
Oil could have leaked past the head gasket.
bad thermostat.
When a temp sensor gets an air bubble around it, it can behave erratically.
If you have air bubbles in your cooling system it sounds like a head gasket or cracked head.
bad thermostat.
or cracked head.
All exactly correct, I had a small leak in one of the head gaskets and it
did exactly that. Unlikely to be a thermostat.
Water may very well be getting into the oil. But those temps are high
enough to keep it boiled off. Not so with oil in the cooling system.
In the old days, you'd get 'chocolate mousse' collecting under the
filler cap. I would be surprised if his PCV valve and hoses weren't
clogged with emulsified oil and coolant.
Also, as has been mentioend before in oyher threads. When the coolant
system is near its at its boiling point in some areas of the engine,
but still below that point elsewhere, odd things begin to happen. Like
geysers. The heat up, deep down its hotter than at the surface, a small
bubble forms, moves up where less pressure lets it expand some, maybe it
cools off enough to collapse, maybe not, it cause some 'burping out' of
water in the water column, now there is less pressure in the system,
larger bubbles explode forcing a lot of water out, repeat but with
different dynamics in the car 'cause there is no replenishment of water
as in a geyser.
Throw in old gummed up radiator caps, questionable radiators, sticking
thermosatats, broken fans, highway followed by stop&go driving, etc.
1 Lucky Texan
as in a geyser.
1 Lucky Texan
Thank you all for your insights and help.
Howie
Howie, It is possible to have water in oil or vice versa but NOT
necessarily both together - it just depends upon what is cracked and where.
With any luck you just have a head gasket problem and it will go away after
replacement. You should expect to get the heads pressure tested with the
valves out to be sure of no cracks.
Ref. the gauge fluctuation, not many people realise that the sender for the
temp gauge neds to be immersed in coolant to operate correctly and if the
fluid leaks or boils away the gauge either will not register at all or will
vary wildly.
We build Subaru engines all day every day and apart from 2.5 Dohc's in the
UK I have NEVER seen a cracked or porous cylinder block on a Subaru.
Good luck David API Engines Ltd England www.apiengines.com
jwillin
