Phase II headgasket 'program'
Downey
from the dealership:
WWP-99 Service Campaign - Cooling System Conditioner
Subaru has determined that certain 1999 through 2002 model year 2.5L
equipped Subaru vehicles may experience an external coolant leak from
the cylinder head gaskets. This is the result of normal relative thermal
expansion and contraction variations of engine parts. As a precautionary
measure, SOA is recommending that a special conditioner be added to the
engine cooling system to prevent leaks from occurring or to correct
existing leaks.
Only early Phase II 2.5 liter engines are affected by this campaign.
Phase I 2.5 liter engines (some 1999 model year and prior years) are not
affected. Countermeasures applied to the manufacturing process for those
2002 and later VINS not affected by this campaign have eliminated the
need for this campaign to be performed on those vehicles.
In the future, it will be necessary to add Genuine Subaru Cooling System
Conditioner to the SUBARU vehicle cooling system whenever the engine
coolant is replaced. The updated recommended service procedure as well
as intervals for coolant replacement will be added to all applicable
service manuals. As a reminder, we will include an update page in the
owner notification letters that should be added to the Owner’s Manual
and Warranty and Maintenance Booklet. We ask you to keep in mind that
replacement of fluids (including Subaru Cooling System Conditioner)
during inspection and maintenance services are not covered under warranty.
If the vehicle owner has this Service Program repair performed promptly,
Subaru will extend coverage under the Subaru Limited Warranty on the
vehicle for cylinder head gasket external coolant leaks to a period of 8
years or 100,000 miles, whichever occurs first. Warranty coverage begins
on the date the vehicle was delivered to the first retail purchaser. If
the vehicle was used as a demonstrator or company vehicle before being
sold at retail, warranty coverage begins on the date the vehicle was
first placed in such service. As a further condition for this extended
warranty coverage to apply, the vehicle owner must have Genuine Subaru
Cooling System Conditioner added to the vehicle at any subsequent
cooling system services at the interval specified in the Warranty and
Maintenance Booklet under the heading “Schedule of Inspection and
Maintenance Services”.
Dealers will automatically be sent an initial quantity of Genuine Subaru
Cooling System Conditioner. Dealer bulletins and affected VIN lists will
be mailed to dealers in early February 2004. Owner notification letters
are scheduled for mailing in stages.
And starting in 2003 what did they do to fix the problem?
Ed Fortmiller | (e-mail address removed) | Hudson MA
* To avoid getting a lot of SPAM junk mail, I have altered my REPLY-TO
* address. PLEASE remove the leading "RUBBISH" from my REPLY address.
* Any Email sent to the address without removing "RUBBISH" will
* automatically be discarded without me even seeing it.
From a good source.
To replace the head gaskets when in warrantee Subaru pays 4 hours flat rate,
usually takes a mechanic 3 hours. The mechanics hate it since they are not
making much. If out of warrantee the flat rate is whopping 13 hours.
Cars which had head gaskets replaced 2 years ago are starting to come back
in again with leaking head gaskets.
If a car now comes in for repair and the mechanic spots a leaking headgasket
they have been told by Subaru to put in that new stop leak, customer does
not get told.
Seems to me that with all these leaking head gasket problems Scooby owners
are having that they should get together and file a class action lawsuit.
Also have heard that customers are ticked off because front rotors are
warping at a much higher rate than normal. Not uncommon to have to turn the
rotors by 10K miles.
Interesting Ed; 4 hours vs. 13 hours?? that is very difficult to believe.
You say a good source. If so I would need alittle more info to believe it.
Share with us??? Also rotors are not a common problem except for some on
this NG. No mention from owners reporting problems in unusually numbers.
eddie
We have a 2000 Outback. We have not received this notice. Have
others here?
'99 Outback with 2.5L and I didn't receive it either,
and I know I'm on the mailing list. At 102k miles, it
doesn't much matter to me. Maybe we don't have the
'certain' vehicles.
KristiKat
