Legacy 2005, A/C intermittent cooling problem
O
Ollie
What we could tell to the dealer, who after 2 visits has not been able to
diagnose the problem in the A/C cooling? When driving on warm day or hot
night with the cooling on, the cold air stops after 10 - 20 minutes and only
very little warm air is coming from the dash vents even with the fan is in
max. By turning the A/C off for 20 minutes, the air flow comes back and the
A/C can be turned on again and it will be doing the cooling for the next
10 - 20 minutes. At the same time the dash board between shift stick and
radio becomes quite hot - over 90 F.
The folklore is telling that the reason could be in
- refrigerant level
- inside temperatire sensor
- pressure senser
- humidity sensor
- compressor
- icing in the evaporator core
If you have seen the same symptoms, what was the reason and how it was
fixed?
Cheers, Ollie
- refrigerant level
- pressure senser
- humidity sensor
- compressor
fixed?
Sounds like the evaporator is icing up.
Try running it on Max A/C only. If the problem doesn't appear after 10-20
minutes, then it's definitely icing, which shouldn't happen on Max A/C
because the cabin air is recirculated and low humidity.
Bob
mdontsb01
