brumby gearshift
dr fang
Hello all,
i have just purchased a 1982 brumby ute. It appears to be in fairly good
order given its age.
The first job is to fix the gearshift linkages, it changes ok, but is a bit
like stirring thick porridge.
Does anyone have any clues as how to replace whatever bushes etc are
required?
Thanks, this is probably the first of many questions!
Tim
Hi Tim!
On Thu, 24 Jun 2004 04:05:33 GMT, "dr fang" <unrepentant
Hello all,
What's a Brumby Ute? I'm assuming it's some kind of Subaru, otherwise
you wouldn't be posting here. IIRC, in '82, there were only a couple
tranny choices, at least in the US; FWD 5spd, 4WD 4spd Hi/Lo, and (I
think) 4WD 4spd Hi only. Not really too much in the way of external
linkage on any of these, just a connecting rod between the shifter and
the selector shaft. The first thing I'd do is change the fluid, run it
a bit, and change it again. If that doesn't help, I'd suggest simply
swapping in a junkyard gear box; probably cheaper and quicker in the
long run.
That said, I think you can pull out the shifter shaft without
splitting the tranny cases; there will be several detent balls and
springs that must be removed, probably covered with threaded caps. I
wouldn't even attempt it 1)without at least a Chiltons, or preferably
a factory manual, and 2)without the resignation that "It's broken
anyway; can't make it any worse."
Good luck! ByeBye! S.
KristiKat
