'99 OB screeching noise
db
I just bought a 1999 Outback. Sometimes when I start the car I hear
screeching noises. After a few minutes of driving the noise disappears.
Any suggestion?
Thanks
D.
Any suggestion?
Check & adjust drive belts?
Check water pump & alternator both ok?
Check cambelt changed at required interval(s)?
Let out mother in law?
Cheers
Cheers
Aircon compressor idler pulley?
I would check the following in order. PS belt>AC belt if
using>alternator>PS pump>timing belt idlers(this will be a pain to
do).
Any suggestion?
Check the alternator belt. The starter has just taken a chunk of power
out of the battery and the alternator is working harder to put it back.
As a result it is harder to turn, so puts a strain on teh belt which is
not as tight as it could be.
My 2c
Alexander26
