4WD 4WS SVX
S
Stephen
I live in Auckland, New Zealand & over the past 15 years we in NZ have
seen a lot of Japanese Domestic Market (JDM) cars coming in with all
sorts of extras - Mazda MX6 4WS 4WD, Subaru STI works cars, Toyota
Soarer etc etc most not available in the USA or Canada.
Well today I took my baby into our local Subaru dealer to get what I
suspected was a wheel bearing replaced - mines a red 1996 with full
leather & moon roof with 110,000kms on the clock.
Yes they confirmed that the bearing need replacing, but while I was
there the service guy showed me 2 4WS versions up on the hoist both
with the same rear steering problem - 1 had been there for nearly 4
weeks!!!! the other for 1 week.
The service guy said that the only information that they could find
was on the net & it was in Japanese - even after translating it, it
actually could not help the sort out what was wrong, they suspected
the rear steering electronics "black box" - they are no longer
susported from Japan as 4WS was only available on approx 250 cars on
the JDM in 1992 - so buyer beware, or if anyone happens to see a
wrecked 4WS version then let the others know as the electronics & rear
stearing box (which sits behind the rear axle) will be as rare as hens
teeth.....
Subaru here in NZ are sending both ECUs back to Japan to be serviced
(hopefully!!) & then get the cars back on the road.
Hope this makes interesting reading for someone...
Steve in New Zealand
How to' for 4WS codes
For those very few who have RHD and 4WS, here are the codes for
deciphering the 4WS check light.
1) Remove the kick panel just beside accelerator pedal.
2) Locate blue wires.
3) Locate black connector. Hold it so that the notch is up.
4) With ignition off, insert one (either one) of the blue wires into
top row, 4th pin from left. (The black connector has 4 pins in the top
row and six in the bottom row)
5) Turn key to on position, but do not start the car.
6) Watch flashing 4WS light on dashboard. Count blinks. Long blinks =
10, Short blinks = 1.
7) Keep watching flashing light until you have remembered the
code/codes
CODE PROBABLE CAUSE
11 Speed sensor - cut/short
13 Steering Wheel Angle Sensor - off centre
14 4WS ECU - no power
21 Steering Wheel Angle Sensor - cut/short or sensor failed
22 Steering Wheel Angle Speed Sensor - cut/short
31 Rear Wheel Steering Sensor and Motor - failed
32 Rear Wheel Steering Sensor - cut/short?@or sensor failed
33 Rear Wheel Steering Speed Sensor - cut/short or sensor failed
34,37 Rear Steering Motor - no power
35 Rear Wheel Steering locked due to short in Steering Motor
36 Rear Steering - Left/Right Lock has been exceeded.
41, 43, 44 4WS ECU failed
42 Rear Wheel Steering Motor - no power due to blown fuse
45 Rear Wheel Steering Motor short, ECU failed
To clear codes (after problem has been resolved):
1) Ignition 'OFF'
2) Remove Fuse SBF7 (4WS) from Fuse Box in Engine Bay. Wait 5 minutes.
3) Reinsert fuse.
4) Recheck as above to ensure all codes have been cleared. No codes =
steady blinks at 1/4 second intervals.
Also check http://www.subaru-svx.net/photos/user.php?paddlesnz|9730
for pictures of the diagnosis connector location.
4WS was standard on JDM VL models of which 1900 were made. The 4WS
system was made by Mitsubushi, so many parts were also used on various
Mistubishi models.
paddlesnz
JAPAN
