2022 Subaru WRX wheel spacers suggestions
Hello All,
I bought a 2022 Subaru WRX a few months back. I am planning to install wheel spaces to have a slight increase in track width. I know it isn't that much but still increases the stability of the car. I have a couple of questions about this
1. Does adding wheel spacers void my vehicle warranty?
2. Is it recommended to add wheel spacers ?
3. If you can suggest good quality spacers it would be great.
Planning to install either of these spacers
https://www.perrin.com/shop/wheel-spacers/subaru-20mm
or
https://www.aeroflowdynamics.com/co...cts/2022-subuaru-wrx-hubcentric-wheel-spacers
Answers:
1. Yes
2. No
3. No
It's a gimic to take your money and by then you've likely had to replace the tires because the outer / inner edges are worn with a slightly more difficult procedure to correctly align the car.
At the end of the day "spacers" and wider track is only going to spit gravel and road debris onto the car along with anything else that is in its path.
beatupscout
