2019 Impreza left headlight turn signal and fog light stopped working
Hi for no apparent reason the left headlight low beam only, the left front turn signal and the left front fog light stopped working. Relay is good. Fuse is good replaced the turn signal bulb the parking lamp works but not the turn signal. Low beam bulb looks fine. Used a test light and there was no power going through the plug. Did not check the passenger side but everything works on that side. I’m all out of ideas
ddm
