2009 Tribeca 3.6L
Help! In the process of replacing plugs and coils, the 3-wire connector for Cyls 1,2,5,6 all broke apart as I disconnected them. I have ordered replacement connectors, then should arrive soon.
FYI, the Connector wire colors for Cyls 1 & 2 are identical in color and stripes.
The Connector wire colors for Cyls 5 & 6 are identical in color and stripes.
My question is, as each connector broke apart exposing the 3 wires contained within each connector, I need to know the order position of the 3 wires ( which color wire goes to the new incoming connector).
I've searched online for any schemes or diagrams but having no luck.
Hope someone's been thru this issue before.
Thanks in advance for any replies.
Regards,
Yay! I found 'em! Thanks to JustAnswer.com
Coil #1
pin1- red/yellow
pin2- white/red
pin3- blue/black
Coil #2
pin1- yellow/green
pin2- white/red
pin3- blue/black
coil #3
pin1- green/white
pin2- white/red
pin3- blue/black
coil #4
pin1- white/blue
pin2- white/red
pin3- blue/black
coil #5
pin1- black/blue
pin2- white/red
pin3- blue/black
coil #6
pin1- black/yellow
pin2- white/red
pin3- blue/black
ddm
