2009 Subaru forester oil leak
Hello, i have a 2009 Forester with a Non-Turbo EJ25. im getting the smell of burning oil in the cabin. there seems to be some kind of a drip on the front driver side of the engine leaking on to the downpipe, im seeing drips sliding down on the engine coolant hose. (not the lower radiator hose). i did the valve cover gaskets less then 100 miles ago and i am not getting any symptoms of a blown head gasket. there is also slight seepage from the oil pressure switch, but it dosent look to be enough to cause the issue im having, also i dont see any streams of coolant going down the front. the engine when left to idle after driving smokes from the amount of oil getting on the downpipe. is there anything on the front of the engine i should look to see if there is any leakage?
mtbe
